Hi Kyle V,
Yes, I tried to read the attribute (using the imgGetAttribute function). The value is being set correctly.
I can not use the CVI_HL Ring with Sleep example, because I'm not using the trigger. I am using the low level grab example right now. The only modification is that I edit the sleep time to this example. You can look at the code below and search for "Leon" to see all my modification. (I only made 2 changes). I think the main point is that I set the sleep time after I open the session in "int OnGrab (void)". Remember I get this code from the example code as well.
Thanks for your help.
/* This sample demonstrates how to continuously acquire pictures */
/* using a low level grab operation */
#include
#include
#include
#include "llgrab.h"
#define _NIWIN
#include "niimaq.h"
// error checking macro
#define errChk(fCall) if (error = (fCall), error < 0) {goto Error;} else
// Window proc
BOOL CALLBACK ImaqSmplProc(HWND hWnd, UINT iMessage, UINT wParam, LONG lParam);
// Error display function
void DisplayIMAQError(Int32 error);
// Snap Callback
int OnGrab (void);
int OnStop (void);
DWORD ImaqThread(LPDWORD lpdwParam);
// windows GUI globals
static HINSTANCE hInst;
static HWND ImaqSmplHwnd;
static HWND HStop, HGrab, HQuit, HIntfName, HFrameRate;
static HANDLE HThread;
// Imaq globals
static SESSION_ID Sid = 0;
static BUFLIST_ID Bid = 0;
static INTERFACE_ID Iid = 0;
static Int8 *ImaqBuffer=NULL; // acquisiton buffer
static Int8 *CopyBuffer=NULL; // copied acquisition buffer
static Int32 CanvasWidth = 512; // width of the display area
static Int32 CanvasHeight = 384; // height of the display area
static Int32 CanvasTop = 10; // top of the display area
static Int32 CanvasLeft = 10; // left of the display area
static Int32 AcqWinWidth;
static Int32 AcqWinHeight;
static BOOL StopGrab = FALSE;
// Leon - modification for free up CPU time
// Define attribute for sleep time
#define IMG_ATTR_SLEEPTIME (_IMG_BASE + 0x03F6)
// end of Leon's modification
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
LPSTR lpszCmdLine, int nCmdShow)
CHAR ImaqSmplClassName[] = "Imaq Sample";
WNDCLASS ImaqSmplClass;
MSG msg;
HWND hTemp;
// register the main window
hInst = hInstance;
if (!hPrevInstance)
ImaqSmplClass.style = CS_HREDRAW | CS_VREDRAW;
ImaqSmplClass.lpfnWndProc = (WNDPROC) ImaqSmplProc;
ImaqSmplClass.cbClsExtra = 0;
ImaqSmplClass.cbWndExtra = 0;
ImaqSmplClass.hInstance = hInstance;
ImaqSmplClass.hIcon = LoadIcon(NULL, IDI_APPLICATION);
ImaqSmplClass.hCursor = LoadCursor (NULL, IDC_ARROW);
ImaqSmplClass.hbrBackground = GetStockObject(LTGRAY_BRUSH);
ImaqSmplClass.lpszMenuName = 0;
ImaqSmplClass.lpszClassName = ImaqSmplClassName;
if (!RegisterClass (&ImaqSmplClass))
return (0);
// creates the main window
ImaqSmplHwnd = CreateWindow(ImaqSmplClassName, "LLGrab", WS_OVERLAPPEDWINDOW | WS_VISIBLE,
CW_USEDEFAULT, CW_USEDEFAULT, 680, 440, NULL, NULL, hInstance, NULL);
// creates the interface name label
if (!(hTemp = CreateWindow("Static","Interface name",ES_LEFT | WS_CHILD | WS_VISIBLE,
540,14,100,20,ImaqSmplHwnd,(HMENU)-1,hInstance,NULL)))
return(FALSE);
// creates the frame rate label
if (!(hTemp = CreateWindow("Static","Frame per second",ES_LEFT | WS_CHILD | WS_VISIBLE,
540,232,140,20,ImaqSmplHwnd,(HMENU)-1,hInstance,NULL)))
return(FALSE);
// creates the interface name edit box
if (!(HIntfName = CreateWindow("Edit","img0",ES_LEFT | WS_CHILD | WS_VISIBLE | WS_BORDER,
540,34,100,20,ImaqSmplHwnd,(HMENU)-1,hInstance,NULL)))
return(FALSE);
// creates the frame rate edit box
if (!(HFrameRate = CreateWindow("Edit","0",ES_LEFT | WS_CHILD | WS_VISIBLE | WS_BORDER,
540,252,100,20,ImaqSmplHwnd,(HMENU)-1,hInstance,NULL)))
return(FALSE);
// creates the Grab button
if (!(HGrab = CreateWindow("Button","Grab",BS_PUSHBUTTON | WS_CHILD | WS_VISIBLE | WS_BORDER,
550,72,80,40,ImaqSmplHwnd,(HMENU)PB_GRAB,hInstance,NULL)))
return(FALSE);
// creates the stop button
if (!(HStop = CreateWindow("Button","Stop",BS_PUSHBUTTON | WS_CHILD | WS_VISIBLE | WS_BORDER,
550,112,80,40,ImaqSmplHwnd,(HMENU)PB_STOP,hInstance,NULL)))
return(FALSE);
EnableWindow(HStop, FALSE);
EnableWindow(HFrameRate, FALSE);
// creates the quit application button
if (!(HQuit = CreateWindow("Button","Quit",BS_DEFPUSHBUTTON | WS_CHILD | WS_VISIBLE,
550,152,80,40,ImaqSmplHwnd,(HMENU)PB_QUIT,hInstance,NULL)))
return(FALSE);
// Display the main window
ShowWindow(ImaqSmplHwnd, SW_SHOW);
UpdateWindow(ImaqSmplHwnd);
while (GetMessage (&msg, NULL, 0, 0))
TranslateMessage (&msg) ;
DispatchMessage (&msg) ;
return (msg.wParam);
// Message proc
WORD wmId;
switch (iMessage)
case WM_COMMAND:
wmId = LOWORD(wParam);
switch (wmId)
case PB_QUIT:
PostQuitMessage(0);
break;
case PB_GRAB:
// Grab button has been hitten
OnGrab();
break;
case PB_STOP:
OnStop();
break;
break;
case WM_DESTROY:
PostQuitMessage(0);
default:
return DefWindowProc(hWnd, iMessage, wParam, lParam);
break;
return 0;
// Function executed when the snap button is clicked
int OnGrab (void)
int error, bufSize, bytesPerPixel;
char intfName[64];
DWORD dwThreadId;
// Get the interface name
GetWindowText(HIntfName, intfName, 64);
// Open an interface and a session
errChk(imgInterfaceOpen (intfName, &Iid));
errChk(imgSessionOpen (Iid, &Sid));
// Set the sleep time to free up the CPU in ms
imgSetAttribute (Sid, IMG_ATTR_SLEEPTIME, 50);
// end of Leon
// Let's check that the Acquisition window is not smaller than the Canvas
errChk(imgGetAttribute (Sid, IMG_ATTR_ROI_WIDTH, &AcqWinWidth));
errChk(imgGetAttribute (Sid, IMG_ATTR_ROI_HEIGHT, &AcqWinHeight));
if(CanvasWidth < AcqWinWidth)
AcqWinWidth = CanvasWidth;
if(CanvasHeight < AcqWinHeight)
AcqWinHeight = CanvasHeight;
// Set the ROI to the size of the Canvas so that it will fit nicely
errChk(imgSetAttribute (Sid, IMG_ATTR_ROI_WIDTH, AcqWinWidth));
errChk(imgSetAttribute (Sid, IMG_ATTR_ROI_HEIGHT, AcqWinHeight));
errChk(imgSetAttribute (Sid, IMG_ATTR_ROWPIXELS, AcqWinWidth));
// create a buffer list with one element
errChk(imgCreateBufList(1, &Bid));
// compute the size of the required buffer
errChk(imgGetAttribute (Sid, IMG_ATTR_BYTESPERPIXEL, &bytesPerPixel));
bufSize = AcqWinWidth * AcqWinHeight * bytesPerPixel;
// alloc our own buffer for storing copy
CopyBuffer = (Int8 *) malloc(bufSize * sizeof (Int8));
// create a buffer and configure the buffer list
errChk(imgCreateBuffer(Sid, FALSE, bufSize, &ImaqBuffer));
/* the following configuration assigns the following to buffer list
element 0:
1) buffer pointer that will contain image
2) size of the buffer for buffer element 0
3) command to loop when this element is reached
errChk(imgSetBufferElement(Bid, 0, IMG_BUFF_ADDRESS, (uInt32)ImaqBuffer));
errChk(imgSetBufferElement(Bid, 0, IMG_BUFF_SIZE, bufSize));
errChk(imgSetBufferElement(Bid, 0, IMG_BUFF_COMMAND, IMG_CMD_LOOP));
// lock down the buffers contained in the buffer list
errChk(imgMemLock(Bid));
// configure the session to use this buffer list
errChk(imgSessionConfigure(Sid, Bid));
// start the acquisition, asynchronous
errChk(imgSessionAcquire(Sid, TRUE, NULL));
StopGrab = FALSE;
// Start the acquisition thread
HThread = CreateThread(NULL, 0, (LPTHREAD_START_ROUTINE) ImaqThread, (LPDWORD*)&StopGrab, 0, &dwThreadId);
if (HThread == NULL)
return 0;
EnableWindow(HStop, TRUE);
EnableWindow(HGrab, FALSE);
EnableWindow(HQuit, FALSE);
Error :
if(error<0)
DisplayIMAQError(error);
return 0;
static int nbFrame = 0, error;
static int t1, t2, currBufNum;
char buffer[32];
// the thread stop when StopGrab goes to TRUE
while(*((BOOL*)lpdwParam) == FALSE)
t2 = GetTickCount();
// Wait at least for the first valid frame
errChk(imgGetAttribute (Sid, IMG_ATTR_LAST_VALID_BUFFER, &currBufNum));
// if no buffer available, wait
if(currBufNum == 0xFFFFFFFF)
errChk(imgSessionWaitSignal (Sid, IMG_FRAME_DONE, IMG_TRIG_POLAR_ACTIVEH, 5000));
// Get the frame after tne next Vertical Blank
errChk(imgSessionCopyBuffer(Sid, 0, CopyBuffer, TRUE));
// Display it using imgPlot
// Note that if you are using a 1424 and a camera with a bitdepth greater
// that 8 bits, you need to set the flag parameter of imgPlot to match
// the bit depth of the camera. See the "snap imgPlot" sample.
errChk(imgPlot ((GUIHNDL)ImaqSmplHwnd, CopyBuffer, 0, 0, AcqWinWidth, AcqWinHeight,
CanvasLeft, CanvasTop, FALSE));
// Calculate the number of frame per seconds every 10 frames
nbFrame++;
if (nbFrame>10)
sprintf(buffer, "%.2f", 1000.0 * (double)nbFrame / (double)(t2-t1));
SetWindowText (HFrameRate, buffer);
t1 = t2;
nbFrame=0;
Error:
if(error<0)
OnStop();
return 0;
int OnStop(void)
int error, bufNum;
DWORD dwResult;
// Stop the thread
StopGrab = TRUE;
// Wait for the thread to end and kill it otherwise
dwResult = WaitForSingleObject(HThread, 2000);
if (dwResult == WAIT_TIMEOUT)
TerminateThread(HThread, 0);
// stop the acquisition
errChk(imgSessionAbort(Sid, &bufNum));
Error:
if(error<0)
// unlock the buffers in the buffer list
if (Bid != 0)
imgMemUnlock(Bid);
// dispose of the buffer
if (ImaqBuffer != NULL)
imgDisposeBuffer(ImaqBuffer);
// close this buffer list
if (Bid != 0)
imgDisposeBufList(Bid, FALSE);
// free our copy buffer
if (CopyBuffer != NULL)
free(CopyBuffer);
// Close the interface and the session
if(Sid != 0)
imgClose (Sid, TRUE);
if(Iid != 0)
imgClose (Iid, TRUE);
EnableWindow(HGrab, TRUE);
EnableWindow(HQuit, TRUE);
CloseHandle (HThread);
return 0;
// in case of error this function will display a dialog box
// with the error message
static Int8 ErrorMessage[256];
memset(ErrorMessage, 0x00, sizeof(ErrorMessage));
// converts error code to a message
imgShowError(error, ErrorMessage);
MessageBox(ImaqSmplHwnd, ErrorMessage, "Imaq Sample", MB_OK);
