12-02-2017 03:08 PM
i have labview 2017 instaled and NI-imaqdx
i can see my cam in NI
but i cant see function pallete on labview
im new here , please understand and help me
thank u
12-04-2017 11:17 AM
Hi Mihai,
Thanks for getting in touch! There are a few things we need to check.
1. Make sure software has been installed in the correct order. LabVIEW 2017 must be installed first, followed by IMAQdx 2017.
2. Make sure IMAQdx is version 2017 or later. LabVIEW should be the lowest versioned software so drivers will support it. I've linked the latest version of Vision Acquisition Software below
NI Vision Acquisition Software 17.1
http://www.ni.com/download/ni-vision-acquisition-software-17.1/6879/en/
3. Make sure LabVIEW 2017 support was installed with the driver. During the driver installation, you should be able to select LabVIEW support, as shown in the screenshot below:
4. Please make sure the files have been installed. After installation, you can navigate to C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib (if on a 64-bit machine) and fine a folder called "vision" which contains the Vision VI's.
5. Please ensure the computer was restarted after installation. If LabVIEW was open during the installation and the computer was not restarted, LabVIEW may not have loaded the components after they were installed. I hope this is helpful!
12-05-2017 05:27 PM
The function palettes could also be hidden. If you go to "Change Visible Palettes", look at the ones that are checked.
12-06-2017 09:01 AM
thank you all
i solved
