Machine Vision
Generate Clock Signal Using 1424 Control Lines
I am using an area scan camera that requires an external clock pulse to generate its own pixel clock. The frame grabber we have is the NI-1424 and I've been reading about pulse generation options for the control lines. Is it possible to generate a clock pulse from one of these control lines using either the camera file generator or the acquisition VI?
Thanks.
Message 1 of 1
(3,516 Views)
