Machine Vision
Get Livestream with GoPro
Hello everyone,
I have a GoPro Session 5 and want to use it to get the live stream and take photo under the control of labview.The Computer will connect it only with wifi. There are a few web page taking about the control with http, but I really got no idea how to use it to control. The links are here.
Does anyone have the experience? Any idea will be appreciated.
Best regard
(5,862 Views)
Hi I haven't worked directly on Gopro Sesssion 5. and i am also on the same process.
-First Switch on the camera and Connection Settings.
-In that get Camera Info which the Gopro's WiFi SSID and Password.
-Once the Connection is setup then try 10.5.5.9:8080 in your browser and if the live feed is coming then it should be easier to get into LabVIEW.
-Use IP Camera Adapter which is shown in below which used to emulate the android camera: http://digital.ni.com/public.nsf/allkb/3D9CEA3E7B26FA4586257A56004E4507
-Once this is setup we should be able to see the camera in MAX.
-Once we have the camera shown up in MAX i believe we can use it for grab.
p.s.: I am also eagerly expecting our GoPro Session 5 with LabVIEW, once i receive i'll add my findings.
uday
(5,827 Views)
Hi Michael,
thanks for your reply.
I will try it and if I can make any progress, if will post the code here.
Best regard
(5,815 Views)
Hello Udka,
have you sucessfully get the live feed from your browser? I have tried with 10.5.5.9:8080, but it returns error 404
(5,765 Views)
I think from the person who developed gopro api at the github answered telling that Live Feed doesn't work in windows.
-But you can browse the images with this url: http://10.5.5.9:8080/videos/DCIM/
uday
(5,756 Views)
