Machine Vision
Get grey values along max feret diameter
Any way to extract gray values along the max feret diameter of a particle from a particle analysis operation?
(4,902 Views)
you can extract the coordinates:
1. Max Feret Diameter Start
2. Max Feret Diameter End
Then use IMAQ Light Meter (Line) to extract the pixel values along the line.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,884 Views)
