Machine Vision
GetImagePixelPtr in wich component ?
Which component has I to install to have the function “imaq getimagepixelptr” in LabView? It is not in “niimaq 3.5”!
Marc.
(4,196 Views)
I have Imaq 3.7 and it is there.
I am surprised you don't have it. Did you check manually in the library ?
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(4,193 Views)
I think you might need the Vision tools to have that function.
Bruce
Bruce Ammons
Ammons Engineering
(4,184 Views)
NI Imaq does not provide this function. You need to install Vision Tools.
Message Edité par ManuelR le 05-29-2007 08:26 AM
Manuel R
AE dans une autre vie
(4,168 Views)
Thank you,
With “Ni vision” that function is OK!
(4,140 Views)
