Machine Vision
GetPixelLine primitive not functioning?
I am using LabView 6.1 with the IMAQ Vision package.
I have a program that uses IMAQ Light Meter (Line). The inputs are wired correctly (and it even worked before!), but it is not functioning. I went into the VI and used probes to find where the error is: GetPixelLine.
I probed the inputs and all three of the pixel intensity outputs. The inputs are correct, but the outputs are all empty arrays.
Does anyone have any idea what is wrong with it and how I can fix it? I would greatly appreciate the help.
Thanks.
(3,179 Views)
Feel free to ignore this, I found the problem.
Not surprisingly, it was not with the IMAQ functions, but rather with the way that my code handled the images.
(3,179 Views)
