Machine Vision
GigE Vision camera JPEG compression
Good afternoon,
I have a Optomotive Velociraptor camera and i am having problems to reach high fps rates because after activate JPEG compression the camera don't deliver images.
I already activated jumbo packets but it is still the same.
I found a topic from 2015 where it is stated that IMAQ does no support camera side compression, i would like to know if this is still true.
https://forums.ni.com/t5/Machine-Vision/Do-IMAQdx-and-NI-hardware-support-GigE-Vision-2-0/td-p/31608...
Thank you
Miguel Mota
(1,518 Views)
That is still correct. JPEG compression on GigE Vision cameras is not currently supported.
(1,483 Views)
