Machine Vision
GigE Vsion images sometimes corrupted
The desired peak bandwidth sets the maximum bandwidth the camera can use. This can be really important (especially when using multiple cameras). If the camera is trying to use more bandwidth then there is available...
I had the same problem in one of my applications. More about this can be found:
http://forums.ni.com/t5/Machine-Vision/black-stripes-bandwith-problem-Vision-Builder-AI/td-p/2483254
In my case the problem was that there are .icd-files that overwrite certain values. Read the thread I mentioned for more information.
I hope you find a solution.
With kind regards,
Tom
Message 11 of 12
(1,230 Views)
BTW: in the attached document you will find screenshots of the required networksettings.
Message 12 of 12
(1,229 Views)
