Machine Vision
Golden Template
I am developing application in vb 6.0 in which i have to comapre some symbols. I use golden template method. I gives error of Invalid Template Descriptor. I tried to make master pattern in vision assistant, but getting same error. How can I make master pattern in vb 6.0 and save it. While comparing, i load the master pattern and use this golden template method
(3,577 Views)
Hello Gurinder,
From your post what i understand is that you are facing some problem in vb programming.How to do this in vb is something you should post on vb forum and not NI Vision forum.
You can find the vi in which implementation of Golden Template Inspection algorithm in NI example finder>>Toolkits And Modules>>Vision>>Functions>>Golden Template Inspection Algorithm.vi
Let me know if the vi is serving your purpos or not.
Hardik
Message Edited by Hardik Asawa on 10-26-2009 09:02 AM
(3,557 Views)
