Machine Vision
Grabing images from & Apply OCR To that image
I m developing a sample application on OCR. At last visit i m posting the same question.But no one can answer me.
Here i Create a Vi for grabbing images from camera. The Images are grab & save to the desired folder.But the OCR is not working on that snap image.
I m  modified some Sample NI VI's for capturing the images & for OCR.
I m new for labview. I cant understand where is the problem in the VI.
i also create a character set file for reading the characters using OCR Training.
so please help me to find the solution.
(3,813 Views)
HI.
Let me give some suggestions regarding your code, (See pictures), and attached an example that you could serve.
Regards.
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
(3,767 Views)
Jonathan Cruz
Thanks for your reply.
I Try this attachment & inserting the sub VI's.
Please see the new attached vi & Sub vi's. And Give me suggestions where i am wrong.
(3,738 Views)
Certainly, the program looks better, but still there are some things to correct you. could attach some images and OCR file (. abc), for improved collaboration with its code.
(3,726 Views)
Thanks for reply,
The images & OCR File is attached. i am not able to set the ROI . I read the NI help file on OCR Training & reading Characters. But i can't understand the difference between these two.
(3,717 Views)
