Machine Vision
Grayscale image
   In the attached Grayscale.vi file,when an input image with only one color(screw image) as background, i am getting a perfect grayscale ouput,but if the background has different color(image with a printer),i am not getting a perfect grayscale image.help me in getting a grayscale ouput,when the given input image has diffrent background color.
Thank you
(4,900 Views)
Could you also attach NIClustering_Cluster.vi?  Was this generated by Vision Assistant?
(4,871 Views)
Hi
   link to download ni_clustering and you can install it
https://decibel.ni.com/content/docs/DOC-4063
It was not generated using vission assistant
Thank you
(4,864 Views)
Hey,
i could not reproduce the behaviour. That means my image is perfect Greyscale as expected. I am using Windows 7 32-Bit and LabVIEW 2012.
(4,845 Views)
   for example you can see in the attached image,in which right side image is the input image and the left image is the grayscale image(output),in the grayscale image atleast we should able to recogonize the objects in the image
Thank you
(4,837 Views)
