Machine Vision
Hardware Triggering PCI 1426
I'm trying to use the hardware trigger using a PCI 1426 in combination with MAX.
I can set the trigger to TTL in MAX, but it does not seem to function.
Snap and grab function just like before setting the triggers, and there is no response using the trigger input on the 1426.
What am I doing wrong? Waht would be the right procedure?
Thanks in advance...
(3,476 Views)
Hi Harry,
I don't think MAX supports Triggering when doing a Snap or Grab, you need a Application for this. You could try the Vision Builder AI
Or if you already have the Vision Development Module you could try the Vision Assistant.
Hope this helps,
Karsten
(3,451 Views)
Could you please tell how you connected the trigger signal into the 1426 card.
(3,374 Views)
