Machine Vision
Has anybody used JAI Camera link Camera CVM4CL with PCI 1428?
I can not trigger and control the Exposure time of the JAI CVM4CL camera link using PCI-1428.
Has anybody done this? It sounds to me that I don't have serial communication via camera link. Any help is much appreciated. Thanks Hamid (Hamid_Yazdi@FMO.COM)
(3,683 Views)
Hamid. As I type this message, an engineer behind me is integrating the serial communication features of the JAI CV-M4 camera with our PCI 1428 board. The serial interface is a bit unique, but he should have it finished in the very near future.
Thanks for you patience.
Kyle V
www.ni.com/ask
(3,683 Views)
OK! Eventually I managed to do some Exposure time control using the dip switches. This is hardware control but for the time being will do the job. The problem is that this camera is set to look at the trigger input by default on camera link port and not the TTL trigger on Hirose connector. Also There is another dip switch that will enable the hardware control. Otherwise it will look at the serial interface as well. I have solved these problems for now, but need to do this programmatically. Hope there will be some news on that.
Hamid
(3,683 Views)
I'd like to use the serial communication too, via cameralink with my PCI-1428 board.
Have you finished to integrate the serial communication features ?
How long this will take ?
thanks for your support.
Olivier M.
(3,683 Views)
