Machine Vision
Has anyone used <i>Integral Technology</i> frame grabbers with Labview?
I would like to use a frame grabber that works fine with the original software. It's an Integral Technology FlashPoint 3D Pro PCI. I have Labview 6i Professional. What do I need to start? Is there anything I can do without a driver dedicated for Labview made by the original manufacturer of the frame grabber?
(3,117 Views)
You won't be able to control your frame grabber from LabVIEW directly without writing a custom driver. However, if you save the images to files using the software that came with your Integral Tech frame grabber, then you can open those files from inside LabVIEW and process them from there with NI-Vision. You won't be able to acquire at 30fps, but if you're application isn't speed critical, then this solution should work. You will still need to install NI-IMAQ (which can be downloaded off of our website), and NI-Vision, which must be purchased separately.
(3,117 Views)
