Machine Vision
Help me find a compact wide-angle or fish-eye lens?
Hi there!  This is an imaging lens question:
I am trying to find a lens that is:
- C mount
- Small and compact.  Size is very important.
- Has a wide field of view ... eg fisheye or wide angle
- Min object distance <= 10 cm
- Image distortion is not a big issue
Currently, I am using this 3mm FL wide-angle lens.  But I'd like to a smaller lens, and preferrably a wider field of view, and still remain 10cm from the object.
I spoke to some vendors and found these options, but none can really meet all my criteria:
Fujinon Fujinon TF2.8DA-8
Similar to current lens, with slight improvements.  But also longer.
Theia Technologies MY125M
Wider field of view, with no distortion.  But longer than current lens.
Fujinon FE185C046HA
Extremely wide field of view.  But is both longer and wider.
http://www.medicollector.com
Message 1 of 11
(5,012 Views)
Try
NET USA , INC.
3037 45th Street
Highland IN 46322, USA
Phone: +1 219 934 9042
Fax: +1 219 934 9047
+1 800 266 5906
info@net-usa-inc.com
www.net-usa-inc.com
If they don't have then you are into specialty lensing that means $$$$.
Edmunds Optical or Thor Labs would be you best bet for hard to find stuff.
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
Message 2 of 11
(5,010 Views)
The format of your camera's sensor will limit your choice of lenses.  What model of camera are you mounting the lens onto?
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
Message 3 of 11
(5,004 Views)
If your camera's sensor is 1/3" format or less, you could use a Kowa 2.7 mm, NF-Mount lens in combination with an NF-Mount to C-Mount adapter, see
Kowa LM3NF
http://www.kowa-usa.com/kowanewweb/lenses/fa13.html
and
Edmund Optics
http://www.edmundoptics.com/products/displayproduct.cfm?productID=3188
Robert Eastlund
Message 4 of 11
(5,002 Views)
Yes, my sensor 1/3".
And I like that little NF lens!  That could be a great option!
Kudos to you!
Message 5 of 11
(4,998 Views)
While we are on the subject of "compactness":
Any suggestions for a smaller camera than this one:
AVT Guppy Pro
I was wondering maybe if there is an NF-mount camera that is Firewire-B?
I am currently using the Guppy Pro F032C.  And AVT advertises it as the "smallest firewire camera in the world" ... If that is correct, then I guess I'll need to go USB in order to get smaller.
Other requirements are:
- Color (preferrably)
- Able to do minimum 30 fps at VGA resolution
- Can trigger shutter using external signal
- Rugged
- Compatible with IMAQdx (eg Firewire-B or DirectShow)
- Good performance in low light conditions (eg autogain)
Message 6 of 11
(4,984 Views)
The AVT Guppy Pro cameras can be produced as board level cameras, see page 8 of 39 of the .pdf located at
http://www.alliedvisiontec.com/fileadmin/content/PDF/Products/Modular_Concept/AVT_ModularConcept_ext...
Sony has begun producing a small form factor firewire B camera, see
http://pro.sony.com/bbsc/ssr/cat-industrialcameras/cat-ieee/product-XCDMV6/
Either of these cameras should be able to take advantage of NF Mount lenses via the NF to C-Mount adapter.
Does the ideal camera need to be compact in X, Y and Z dimensions?
Robert Eastlund
Message 7 of 11
(4,973 Views)
Interesting!  thank you!
I guess my ideal camera would be as small as possible in all dimensions.
At the moment, I prefer the idea of changing the lens.  Would just make things easier, I think.
Quick question:  The NF-mount lens you referred to looks interesting.  But the adapter from EO is a "micro-video to C-mount" adapter.  Is "micro-video" the same as NF?  I did some googling, and can't seem to confirm this.  I have seen micro-video referred to as "S-mount" and as "M12".  Are they all the same thing?
Message 8 of 11
(4,947 Views)
I had confused the two mounts.  The µ-Video is an M12 x 0.5mm.  The NF-Mount is M17 x 0.75mm.  Looking at the µ-Video adapter, it would take a machine shop to mill the adapter accomadate the M17 x 0.75mm thread of the Kowa lens.
Robert Eastlund
Message 9 of 11
(4,945 Views)
In the past, I have worked with SK Grimes to have custom lens adapters created, see http://www.skgrimes.com/contact-us.
Robert Eastlund
Message 10 of 11
(4,943 Views)
