Machine Vision
Help with my Camera!
I have an instrumentation project due tomorrow and I am stuck with camera vi
please can you help solve my problem.
I tried different image types but nothing worked.
Im attaching the vi, i want to measure the area of an object+ dimensions
Im getting an error due to image type problems (although im changing the type)
thank you
Message 1 of 11
(4,922 Views)
Try to use IMAQ Extract Color Planes (with HSL Color Mode, then use Hue plane) instead of IMAQ Cast Image.
Andrey.
Message 2 of 11
(4,922 Views)
Hello Andrey Dmitriev,
Ou minya ni paloshayetsa Cameara vi
I dont think I hae connected the right outputs
Can you show me the how to connect IMAQ Extract Color Planes ?
Thank you
Message 3 of 11
(4,919 Views)
Try in that way:
Message 4 of 11
(4,916 Views)
Dmitriev, What else should i change?
For the Intesity Plane, I created a constant and named it that way.
What happens to the upper code?
Do i remove it?
Message 5 of 11
(4,914 Views)
I still receiving the error; but this time not an image.
Message 6 of 11
(4,907 Views)
It happened because you have connected to output "Red or Hue Plane out", but shoud use output "Blue or Luma or Val or Inten Plane out" instead.
Message 7 of 11
(4,901 Views)
What Camera do you have?
Can you grab a picture from MAX?
kind regards,
Ion R.
Message 8 of 11
(4,884 Views)
Andrey, it worked without crashing.
The project was postponed 1 week 🙂
It gives a reading area, number of objects, and ratio of length and width.
But the number of objects it is giving changes continously when i place the camera infront 1 10x10 object.
How can I solve this problem?
About the area, how can i change the units to show mm^2
I placed the indicator for the image out but it does not show.
ion.rosca I have a USB camera that grabs an image continously(more like a video)
I am uploading the recent vi, how can i solve the other problems?
Thank you
Message 9 of 11
(4,878 Views)
Andrey, Do you know how to change the dimensions to mm^2?( what are the current dimensions?)
and how to see image out?
can I see what are the objects its identifing?
Message 10 of 11
(4,857 Views)
