Machine Vision
Help with synchronizing a Pulinix TM-1300 Camera and PXI-1422 framegrabber to external trigger
Hi David,
There are several options for synchronizing your camera with an external trigger. You can configure the PXI-1422 to trigger in several different ways. You can trigger the start of the acquisition, trigger each buffer in an acquisition, etc. There are several examples in LabVIEW or LabWindows/CVI that demonstrate how to perform this triggering.
Additionally, you can learn more about triggering in our Developer's Zone at http://zone.ni.com/ and selecting Resource Library >> Vision >> Signal I/O.
Matthew Smith
Applications Engineering
(3,147 Views)
