Machine Vision
Hi, I have a NI 1409 framegrabber but I can't to connect it to my camera CS 3730, Does somebady can help me?
This camera CD 3730 DC is a Double speed 50/100 fps progressive scan camera, it have several functional modes, one of then is interlaced or not interlaced mode. I configured it the all forms possible but I have not good luck. I read NI 1409 data sheet, and this framegrabber can work in different forms with different interfaces, I set it but I haven�t good luck. If any can help me, I will appreciate it.
(2,890 Views)
I'm assuming that this is your camera :
http://www.net-gmbh.com/_English/Products/Progressive_Scan_Cameras/progressive_scan_cameras.html
If so, make sure that you are have set the camera file in Measurement & Automation Explorer called 60 Hz Progressive Scan. Try playing with some of the settings in the Properties page.
The following documents may also have information that could help you:
http://digital.ni.com/public.nsf/websearch/F63B9EB06F73C5D586256A62005540AC
http://digital.ni.com/public.nsf/websearch/5C735DF78AC371C586256B5100641F9B
Although they do not refer to your camera, they do seem similar.
Hope this helps-
Julie
(2,890 Views)
