Machine Vision
Histogram matching
    I how to get similar type of  histogram matching for the attached vi file.
Example of histogram matching file attached.
Input image is also attached.
Thank you.
(5,252 Views)
hi Madhubalan,
can you be a little more specific about your application and what kind of histogramm you would like to get from your picture?
regards
Michael
(5,194 Views)
Hi Michael,
              I have attached a pdf,i am using the techique followed in this pdf to find the histogram matching.As per the technique ,in the histogram output it should higlight the area of the trageted object,in mine,the targeted object is the screw.
(5,187 Views)
hi Madhubalan,
dou you still have the same problem?
I took a look at your code, since I don't have a camera right here, it was quite hard to understand what exactly you tried to achieve, and where the problem is.
Can you tell us a little more about what you try to do, what works, and what doesn't?
Oliver
(5,115 Views)
Hi Oliver,
             I want to get ouput image similar to the attached image file.In this image file you can see,when comparing two similar images,the identical objects in the images has to highlighted in the ouput image as per the technique used in the attached pdf file.
Also i have attached a zip file in which you can check,if you can modify for me to get the desired output, it will be helpful
Thank you
(5,110 Views)
Hi Oliver,
             The code which you had look at it gives masked image(binary image,after segmenting) as a ouput when you give the attached image file as input.From this i would like to get by the histogram matching image as ouput as mentioned in the previous ouput,i.e when comparing the binary image(masked image output) and a the given the input image(color image), the ouput should compare the objects similar in the output binary image and input color image and in the histogram matching output,it should display the image with highlighting the similar objects.
Thank you
(5,104 Views)
