Are you just asking how to display the image on the front panel? If so, the image display was introduced with LabVIEW 7 and IMAQ 2.6, I believe. You can just put one on your front panel, then wire your image to it as an indicator in the block diagram.
Bruce
Bruce Ammons
Ammons Engineering
