07-31-2019 10:34 PM
Is there any way to automatically find the edge of the white ball or Center point of the white ball ?
08-02-2019 11:05 AM
Hi Tienzuen,
You're probably going to use the Find Circular Edge function to detect the ball, then get center/radius from there. This is a pretty common problem so you'll likely find various approaches with a search through our forums. I've put some links below:
determine center and radius of circles
https://forums.ni.com/t5/LabVIEW/determine-center-and-radius-of-circles/td-p/3220312
Best way to find the center of a circle
https://forums.ni.com/t5/LabVIEW/Best-way-to-find-the-center-of-a-circle/m-p/3881524
Find Circular Edge
https://forums.ni.com/t5/Machine-Vision/Find-Circular-Edge/td-p/3633768
08-02-2019
11:50 AM
- last edited on
09-04-2025
02:03 PM
by
Content Cleaner
Hi.
You should try to do dark field illumination to get the edge of the ball easier to identify.
It will help the algorithm to extract the edges.
Look at Darkfield illumination
