Machine Vision
How can I get "IMAQ Line Fit" stable (with the same points)
Hallo Toine,
Would you give me your test vi and explain it to me how you test your application?
Because as you saw in my test.vi I set your vi in a loop and let it run more than 300 times.
If you give your manner to me, I would check it again.
Hear from you.
Hossein
Message 11 of 12
(768 Views)
Hallo Toine,
I cannot understand what you mean with  '"IMAQ Line Fit" is NOT STABLE". Would you please explain what you get as result and what you exactlly mean.
If I run your vi more than 300 times, I get an image (see attachment).
Is that correct or do you need other things?
Hossein
Message 12 of 12
(758 Views)
