Machine Vision
How can I get the thresholded pixels from IMAQ OCR Session in Labview 2009
Hello Everybody,
I want to show the results of any OCR settings (threshold, erosions) to the user, but OCR threshold algorithms are not available in NI Vision Concepts Manual.
I attached a VI and an example image. You will understand the problem by checking the VI.
Thank you for your help.
Marton Czigany
Sanxo-Systems
(3,297 Views)
Finally the example image.
(3,296 Views)
You recieve the character report cluster from the OCR read3 VI, use it to perform manual treshold in the image using the standard treshold functions.
OCR will perform very poorly on the kind of images you supplied, you will probably need some self made function to determine the character bounding rectangle.
By the way, isnt the example you supplied an image of some marked metalurgical product e.g. ingot. I remember those things having such dotted characters.
(3,253 Views)
