I would suspect you could edit the icd file and take out the line that sets the exposure time. This would leave the camera in whatever state it started in.
Another option would be to set up an attribute that you can control the exposure time. The attributes are always updated when you start an acquisition, if I remember correctly. I think you could set up your acquisition, set the attribute, then start the acquisition.
Bruce
Bruce Ammons
Ammons Engineering
