Machine Vision
How can I measure the thickness of a circle line?
we try to measure the thickness of a circle line to find out if the circle is round or if there is any deviation in the circle. By now we are using the FindEdges tool and measure the circle at different points.but this is not sufficient.
Does anyone has an idea how we can measure the thickness of the line of a circle?
thanks
Oliver
(3,835 Views)
Can you post some example data?
Randall Pursley
(3,830 Views)
yes I have two pictures.
Picture 1 is the original, Picture 2 is the "working picture"
greetings
Oliver
(3,823 Views)
Try to use "Find Circular Edge" tool from NI Vision Assistant. It comes with Lab View Vision Module. See attachment. Is this helpful?
(3,817 Views)
