It still isn't clear to me what you are trying to do. I don't have the time to dig into the KLI-2113 manual to figure out the details.
If I understand correctly, your imager is returning an image that is 79x295 pixels. The size of the image has nothing to do with time, which confuses me when you refer to plotting vs. time.
Do you have a lens on the imager? The results always make much more sense when there is a lens to create an image. You can tell if the image is upside down, reversed, dark, light, etc. Using an IMAQ image display can help also.
It almost looks like the CCD you are using only has about 64 active lines, and the last 15 are just garbage values that are close to zero.
The only standard way to control the integrati
on time and other parameters from LabVIEW is by using serial communications. You can either use the built in serial lines on the 1424, or use the PC serial port. From a quick browse through the KLI-2113 manual, I wasn't sure if any serial control is available.
Good luck trying to figure it all out.
Bruce
Bruce Ammons
Ammons Engineering
