Machine Vision
How can I select an ROI so that I can remove it?
I need to select a single ROI among other ROI's on an image in order to remove only that selected ROI.
(3,869 Views)
Dear Josey,
in IMAQ Vision 2000 just select the ROI to be deleted by putting your mouse indicator on it and then press ...
(3,869 Views)
Thanks, I didn't try that. Do you know if it's possible to obtain the Regions Collection Item number of the selected Region before the Region is deleted?
(3,869 Views)
Josey,
Here is a small example that shows how to interactively create and delete contours in an ROI. When a contour is deleted, it's descriptor and index in the ROI are returned.
Brent Runnels
(3,869 Views)
How do I get the index of a deleted contour in IMAQ Vision for LabWindows/CVI?
Guilherme Cardoso
(3,869 Views)
