On the toolbar under "Color", select "Extract Color Planes". You can extract a single color (red, green, or blue), hue and saturation info, or intensity information. Intensity is probably going to closest to what you would get if you used a grayscale camera, but the other options might be useful for you.
Bruce
Bruce Ammons
Ammons Engineering
