Machine Vision
How can LV determine a mean value of 10 pictures?
Hello together,
I would like determine a mean value picture. Because the signal-to-noise ratio is to high. Therfore I get a picture (see Attachment "Original_Picture.png") 10 times (For Loop) and want to calculate the 10 pictures to a 1 mean value picture. I tried it with the Image processing Operator Imaq MulDiv (see Attachment "Example.png"). Unfortunately the 1 mean value picture (see Attachment "Result_Image.png") isn't that what I need.
I hope anybody can help me.
zäpfle
(4,220 Views)
Simple add 10 images together, then divide by 10, something like that:
Be careful with overflow (therefore I using SGL type for accumulation). If your camera deliver U8, then you can use U16 for accumulation up to 256 images.
(my web cam deliver RGB, so I have extracted Intencity component before accumulation)
Andrey.
(4,211 Views)
Hi Andrey,
Thanks for the answer. I tried like your VI (see attachment), but unfortunately it doesn't works. I think the images will added but not divided. Do you see my mistake?
greetings
zäpfle
(4,200 Views)
Accepted by topic author zäpfle
zäpfle wrote:
Hi Andrey,
greetings
zäpfle
It seems to be that you have overflow. If your images are U8 (8 bit grayscale), then accumulation buffer should be at least I16 (or SGL).
Another point - you may have race condition caused by IMAQ Dispose at the end. Take a note that images theoretically can be disposed before displaying, so you will see nothing at the end.
Andrey.
(4,196 Views)
(4,133 Views)
