Machine Vision
How can i make data logging to EVS RT?
I have Basler camera connected to EVS RT with terminal Block and I have done inspection project real time it gives me Pass and different types of Fail
I want to transfer the results data to my EVS, as Excel sheet or dbase file.
(4,182 Views)
Frank,
What specifically do you mean by ‘transfer the results data to my EVS’? Do you mean you want to take the data from your EVS after processing and open them using an Excel-type program on your development computer?
Blake C.
www.ni.com/support
(4,158 Views)
I want to save the inspection results in any type of data base on my EVS, then i will transfer this data to my pc and analyze it.
(4,153 Views)
I have been able to accomplish this by using a 3rd party HMI (specifically Red Lion G3 Series http://www.redlion.net/Products/HumanMachineInterface/OperatorInterface/G306.html).  You would need to setup modbus communication beetween the HMI and EVS, and also setup the HMI to log the results onto its compact flash.  You can then access the file through its built-in web server.  Having said this, it would be more convenient to access the data directly from the EVS.
(4,143 Views)
Your answer is for the second part of the question, and my problem in the first part of the question.
How to save the inspection results to my EVS???
(4,139 Views)
