Machine Vision
How can we get the strobe signal from Basler A601f camera
Hi all,
I am using Basler A601f camera for one of my application. i need to get the strobe signal from the camera to control the strobe light. I have gone through manual, it seems we need to configure in corresponding regeisters to get the strobe light some thing like that. cant we get default strobe signal from the output port or what is the way get the strobe signal any body have the code to do that.
Thanks in Advance
Kalanga
(4,097 Views)
It looks like the default is for Output Port 0 to transmit a Integration Enabled (IntEn) signal to let you know when the sensor is integrating and this signal can be used with a strobe light to synchonize with the camera acquisition. See:
http://www.baslerweb.com/downloads/12065/A600f_Users_Manual.pdf
section 2.5.2
Have you tried monitoring output 0 to verify it pulses when the camera acquires an image...easiest way would be to trigger the camera and make sure this line goes high for the exposure time whenever you trigger the camera. I would contact Basler if you have more questions on their camera.
Hope this helps,
Brad
(4,065 Views)
