Machine Vision
How could I use PCI-1422 to capture images from Megaplus 1.6i camera?
Because PCI-1422 has 100 pins and Megaplus 1.6i camera has only 68 pins.I tried many times but could not get the images.How should I conennct the Megaplus 1.6i camera to the PCI-1422 correctly? How could I capture imeges from Megaplus 1.6i by PCI-1422?Have you used PCI-1422 to capure the images from Megaplus 1.6i?
Thank you very much.
(3,512 Views)
The simplest solution is to get the cable for the camera.
IMAQ Cables
or I have attached screenshots of the cable pinout for you.
(3,512 Views)
1.Could you tell me the product SN of the cable(68pin-100pin)for purchase?
2.I think maybe the Megeplus 1.6i camera need a special configuration file.Could you send me a configuration file of Megeplus 1.6i camera? dchli@sina.com
(3,512 Views)
Everyting you want to know should be in the Megeplus 1.6i entry in the Camera Advisor
Amaury,
NI Applications Engineer.
(3,512 Views)
Amaury,
(3,512 Views)
Could you tell me the function of the camera file in detail?When I connect different cameras to PCI-1422,do we need to use different camera file?
(3,512 Views)
