Machine Vision
How do I access imaqdx's Bayer Filter algorithm?
Lost and Found,
Thank you. My only other issue is that IMAQdx Get Image Data is producing 8 bit data, not 16 bit data.  Did you experience this at all?
Message 11 of 16
(2,285 Views)
Sorry, I didn't realize another student was logged in when I posted that. But it was actually from me.
Message 12 of 16
(2,282 Views)
Yes, actually, the data is 8-bit that I receive, hence the steps I took. My reference to 16-bit is that I understand that is what is actually being sent from the camera. I believe this has something to do with how Labview VIs must work, however (very C-ish in terms of data type handling).
Message 13 of 16
(2,274 Views)
Got it, I understand what you're saying now. Thank you very much for your help!
Message 14 of 16
(2,258 Views)
I am using LV 2009 & NI-IMAQ 4.3.1.  Is that too early to contain IMAQarrayToImage.vi?
If so, is there an alternative?
Thanks.
Tim
Message 15 of 16
(1,673 Views)
Did "IMAQdx Get Image Data VI" really capture raw Bayer data?
I am having a tough time using it to capture raw Bayer output from a Point Grey Chameleon.
For some reason it always grabs 4 times the amount of data.  I think it is really grabbing RGBA data.
But Point Grey assures me that the their camera doesn't have any color processing ability and
outputs in raw.
ANy idea?
Message 16 of 16
(1,660 Views)
