Machine Vision
How do I capture a series of frames using the 1409?
I want to capture a series of frames using the 1409 onto any possible format(BMP,JPEG, etc...) , but I can't figure out how. Can somebody please help?
(3,174 Views)
First, make sure your camera works fine in MAX. If you can acquire images, you are all set.
Take a look at the IMAQ examples. You need to use a sequence to acquire the images. After you have acquired the images, you can wire them into a for loop and save each one in whatever format you want.
Bruce
Bruce Ammons
Ammons Engineering
(3,174 Views)
Bob,
There are two ways of doing this, depending wether you have NI-IMAQ only or if you have the IMAQ Vision toolkit. In either case, you will find a couple of examples in the Vision >> File I/O section of NI Developer Zone. For the way you wrote your question I assume you don't have IMAQ Vision, well, there is an example in that section for saving images when you don't have the Vision toolkit.
I hope this helps.
Nestor Sanchez
IMAQ/Motion Support
Nestor
(3,174 Views)
