Machine Vision
How do I copy images to buffer in Vision Builder Eval
I have an evaluation copy of Vision Builder.
I want to load images from files and do an image divide, yet when I copy images to the buffers, the buffers remain empty. Help!
(3,033 Views)
It sounds like you're using the Vision Builder AI eval and launching the Image Assistant tool to process your image. Buffers in the Image Assistant don't carry over to other steps. However, in one session of Image Assistant you should be able to save an image to a buffer and retrieve it in the same session. If this is not the case, then you should go to ni.com/ask to get in touch with an NI Applications Engineer.
Kyle V
(3,033 Views)
