Machine Vision
How do I extract a circular particle from inside a square line?
Hi!
I have a binarized image, where I have circles inside squares (see attached image "binarized.bmp").
I want to remove the square, and only keep the circle. But when I run a particle filter, it removes both the square and the circle. I have some circles left in my filtered image, but not as many as I would wish (see attached image "filtered.bmp").
This is my particle filter:
//Remove small and large blobs
filterCriteria[0].parameter = IMAQ_AREA;
filterCriteria[0].lower = 100;
filterCriteria[0].upper = 30000;
filterCriteria[0].exclude = TRUE;
//Remove squares
filterCriteria[1].parameter = IMAQ_HEYWOOD;
filterCriteria[1].lower = (float) 0.7;
filterCriteria[1].upper = (float)1.3;
fi
lterCriteria[1].exclude = TRUE;
//Set border size of the image to make imaqConvolve work
imaqSetBorderSize(myBinaryImage,3);
//Run the particle filter
if(!imaqParticleFilter (myBinaryImage, myBinaryImage, filterCriteria, 2,TRUE, TRUE)){
printf("ERROR: imaqParticleFilter(): '%s'\n",imaqGetErrorText(imaqGetLastError()));
How can I be sure to extract the circles?
Thanks!
(3,263 Views)
Try sorting on size first if you know approximately their size. Then sort on hydraulic radius, type, or elongation factor to get rid of particles with different shapes. I tried to keep size (remove with exclude) 60-300 pixels and exclude (remove) hydraulic radius 0,7-1,8 with success.
(3,263 Views)
Thanks, Torten!
What parameters would you suggest for "type" and "elongation factor"?
Torbjørn
(3,263 Views)
Good Afternoon,
I also experimented with your image. I used particle filtering techniques that were similiar to yours.
filterCriteria[0].lower = 275;
filterCriteria[0].exclude = FALSE;
//Remove squares
filterCriteria[1].upper = (float)1.5;
filterCriteria[1].exclude = TRUE;
filterCriteria[0].lower = 0;
filterCriteria[0].upper = 60;
This also maintained all 5 of the circles.
Sincerely,
Will
(3,263 Views)
