Machine Vision
How do I grab an image(JPEG) from the Web(http://)
How do I grab an image(JPEG) from the Web(http://) using the datasocket in LabView 6? It seems to work fine with audio files(.wav), but what about images?(and video) I would rather not use ftp. Is there a simple solution for this? Would appreciate some help! Thanks
(3,089 Views)
"Proably the reason this question has gone so long without an answer is that the Vision forum only covers our NI Image Acquisition hardware (along with all NI Vision software), and not LabVIEW Datasocket over http. LabVIEW software is covered in the LabVIEW forum under the LabVIEW General section, which is serviced by a different set of Enthusiasts and experts. If you ask your questions there, you should get a quick response."
(3,089 Views)
