Machine Vision
How do I make an executable that includes vision development module?
I am trying to make an executable from a labview program that uses the avi tools from the 2012 vision development module to open and read each frame of the avi file. The executable will be used on computers that do not have labview or vision development. When I make the executable I make an installer that includes the labview 2012 runtime engine and the vision development 2012 runtime engine. When I attempt to open my executable everything works properly other than the fact that a blank screen is displayed and the avi frames cannot be seen. The executable even reads the proper frame rate for the avi file that is selected in the executable. I do not understand why the video is not showing up. Any advice would be much appreciated.
Rob
(3,425 Views)
Hi Rob,
Welcome to the NI Discussion Forums! Do you have the proper video codecs installed on the deployment machines? The IMAQ AVI functions use the codecs installed on your computer to process AVI files.
(3,415 Views)
