Machine Vision
How do I mirror an image?
I need to get the mirror image of the original. How do I do that using IMAQ w/ VB6?
Thanks!
(5,788 Views)
Hey,
I can't remember the exact function in VB but in LabVIEW its IMAQ Symmetry.
Try looking for that?
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(5,787 Views)
Hi Steverino,
Adam is correct.  There is a symmetry method that you can use.  The best resource to check out is the NI-Vision Visual Basic Reference Help.  It should be located in your C:\Program Files\National Instruments\Vision\Documentation directory, and will have the filename cwimaq.chm.  This will show you the parameters to use, the types of operations (vertical, horizontal, etc.) and some example code.
Brandon M.
(5,765 Views)
