Machine Vision
How do I use ActiveX to include live video from my SNC-RZ30P?
Hi, I'm trying to establish a processcontrol over the web and want to include live picture and controllfunctions for my Sony SNC-RZ30P? What is the best way to do this and how is this done?
(3,105 Views)
Sunhill,
You should follow the normal instructions for using ActiveX controls in LabVIEW, if Sony has a viewer that can 'play' video then you are set, if not you might need to constantly call a function that will retrieve the image buffer from memory and display it in LabVIEW. For instructions on using ActiveX please check the Development Library, the section called ActiveX >> General has some information on this.
Otherwise I would advise you to post the question in the LabVIEW Users Group as well.
Good luck!
Nestor.
Nestor
(3,105 Views)
