Machine Vision
How do I use the IMAQ Fit Ellipse vi?
I collect at set of edge-coordinates by using the "IMAQ Find circular Edge"-vi and try to use the radial points it produces to make the "IMAQ Fit Ellipse"-vi calculate a best fit ellipse. However, I don't get any results that makes sense.
I wonder what I'm doing wrong here, any suggestions?
Message 1 of 8
(4,570 Views)
I reproduced the problem and we are looking into it. I will let you know what I find. Thanks for your help,
Brad Buchanan
Message 2 of 8
(4,569 Views)
This will be fixed in the next release of Vision. If you need immediate resolution to this issue, please email www.ni.com/ask
Brad Buchanan
IMAQ Product Support Engineer
Message 3 of 8
(4,569 Views)
Is this problem fixed yet? Or have I to mail also?
/thomas
Message 4 of 8
(4,569 Views)
I found the answer myself. It is fixed in the version 6.0.5 update for Vision
/thomas-j
Message 5 of 8
(4,569 Views)
In case anyone else in wondering where to find the Vision 6.0.5 update, here is a direct link to the Vision for LabVIEW update.
Message 6 of 8
(4,569 Views)
I'd like to detect circles in a 8 bit image using the binary information.how do I connect IMAQ Fit Circle with 8 bit image?I don't know how to use IMAQ Fit Circle.
Message 7 of 8
(4,568 Views)
In the 'IMAQ Fit Ellipse.vi", depends on the border position, the "Minor Axes" is greater then the "Major Axes".
I´m using LabVIEW 6.1 and IMAQ Vision 6.0 with the update 6.0.5 discussed above.
What´s the problem?
Thank you and sorry my poor english
Message 8 of 8
(4,425 Views)
