Machine Vision
How do I wire a new cxamera to a PCI-1424
I have a custom camera that I am trying to interface to a PCI-1424 through a SCB-100 cable. I need to know which positions to hook up LVAL and FVAL. They are differential and the board is a LVDS PCI-1424. I am using a profile from the distribution CD. It does not tell you how to hook up the enables. When I Edit the ICD file I find that the enable are defined there as HEnable and Venable with octal ? numbers after them. What does this mean in terms of enable A-D and can I change them through this file rather than rewiring the terminals.
(2,971 Views)
We don't support custom camera files, so the best way to get a camera file made is to submit a request by calling in to the technical support line.
Jack Arnold
Application Engineer
(2,971 Views)
