Machine Vision
How does IMAQ classify process the image?
Hi, after I create the Classifier file by NI Classification Training Interface I used the function IMAQ Classify in order to classify object in an image, the image on the input of the function was a grayscale image. Finally the classification worked well, but I didn't understand how the function work. I didn't undestand if the image, that passes through in the function, is processed in order to obtain a thresholded image that stand out the object in order to achive all its features. And if that is right which value of threshold the function IMAQ Classify use to do it (maybe the value that I used in NI Classification Training Interface)?
Message 1 of 1
(2,460 Views)
