Machine Vision
How many trigger outputs can I use simultaneously for imaq 1422?
Hi~ I am using IMAQ 1422.
I want to control camera with on-board trigger. But I
found I can use just two triggers simultaneous. Am I
wrong? I want to use four triggers.
Thanks in advance!
(2,990 Views)
The user manual of the page 3-5 for the NI 1422 addresses trigger control under "Start Trigger":
http://digital.ni.com/manuals.nsf/webAdvsearch/79146F957A66E15886256A3F0077560E?OpenDocument
This section states "You can use all four external
triggers and up to four RTSI bus triggers simultaneously."
R. Blake
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(2,990 Views)
