Machine Vision
How performance meter in vision assistant calculates estimation time
I want to make an OCR system and I have some image analysis steps before OCR session like histogram,line profile and brightness so I used NI vision assistant and calculated estimation time, std dev and lonngest inspection time for each step using performance meter and now i want that i should find these results manually also without performance meter and it should be matching also...but as I told you earlier I am unable to do so...
I have tried also using your VIs as reference but failed...and i dont how to find line coordinates in IMAQ line profile VI..
Please help
Thanking you
Message 11 of 11
(1,152 Views)
