Machine Vision
How reliable the pattern matching is?
Hi, if using pattern matching to identify different people by using the eyes section as the matching template. How reliable it would be?
Thanks.
(3,537 Views)
Hello;
That is a too general question. You probably need to be more specific about:
Reliable in what sense?
Hos is you application going to be set up?
Regards
Filipe A.
(3,537 Views)
Hi, I'm building a security system which can identify a registered person and non-registered person. A registered person has his/her eyes section image saved as a template image. I'd like to know the percentage that this system can work if i set up the " Minium Match Score" as 900.
Thank you.
(3,537 Views)
