Machine Vision
How to acquire image from S-video camera
I have a camera with S-video interface. I use a S-video to USB adaptor to acquire the images from my camera. Popular video editor/maker softwares, for example Windows Movie Maker, ULead VideoStudio, etc.. are able to display the video capture from my camera (using the same S-video to USB adaptor). Thus, I think the adaptor transferred the camera to an USB Directshow camera already? However I cannot grab images/video using Labview. I have installed IMAQdx, and I can use the same LabView VI to grab images/video from my USB camera.
Is there any suggestion for my case?
Thanks.
(3,125 Views)
Make sure you are using the right color channel, in most cases YYUV will not display.  Use RGB.  Also try changing the resolution settings.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,923 Views)
