Machine Vision
How to acquire images from a plug and play Webcam without using IMAQdx
I want to add a small window with the images from a plug and play webcam.
So this window will be on my vi.
I installed NI-IMAQ and NI-IMAQdx. But NI-IMAQdx needs a license wich costs around 500 euros.
I may see images from the webcam in NI-MAX
Still when i add IMAQdx vi it does not work. Also with NI-IMAQ.
Anybody knows another way of capturing images from a webcam without using IMAQdx
Thanks in advance
Marco Silveira da Cunha
(1,286 Views)
IMAQdx is the right sdk to use to acquire from a webcam.
Being able to see and acquire from a camera in MAX and not in LabVIEW usually means the IMAQdx license is not activated on the computer.
I suggest you check that in the license manager.
Sami
(1,259 Views)
