04-03-2014 06:57 PM
Hello Everyone!
I am making a video from webcam an dsaving it for further useage.
The problem is the size of the video is very large. I want to reduce the size and and also to change the bitrate of the video
Thanks in advance,
Regards
04-04-2014 08:37 AM
Hi 12444444,
You could write a compressed AVI file to make your file size smaller. Here is a KnowledgeBase article about how to do that: http://digital.ni.com/public.nsf/allkb/0A4D5BF47FD3FF0186256E9A004FD671
As for changing the bitrate, I'm afraid that's not something you'll be able to tweak programmatically in LabVIEW. If you can get a different camera with a different bitrate, then that would be fine.
04-04-2014 11:11 AM
Hi Julian,
This article is very heplful. I have tried the basic DV Video Encoder and size of the file is significantly reduced.
But the bitrate is also affected.
I want to know is there any connection between them?
04-07-2014 10:03 AM
I think that this webpage explains fairly well what the connection is between bitrate and file size: http://www.ehow.com/info_12117426_bitrate-mean-video.html
Jeremy P.
04-08-2014 09:04 PM
Check videohelp.com They have a whole selection of tools and tutorials for all kinds of video manipulations.
